How To Use The Offset Tool To Offset From The Edge Of An Extruded Shape?
JCL-CD
JCL-CD
Hello Everyone -
I looked into this a great deal before posting this question, but I still can't find the answer.  I need to be able to use the offset tool in the sketch menu to be able to offset from the edge of even a simple extruded circle, but I can't figure out how to do that?  Fusion will not let me select the edge to offset from as you can see in my screenshot below.  How would I go about doing this simple task?
Thank you.
jeff_strater
to use Sketch Offset, you must first project the edge into the sketch using the Project tool.  Sketch Offset only works on sketch geometry, and an edge is not a sketch curve.
Jeff Strater
Engineering Director
kacper.suchomski
Hi
If it is not automatically projected, please project it manually into the sketch first.
Kacper Suchomski
JCL-CD
Thank you both for the help!  I greatly appreciate it. Projecting the edge allowed me to use the offset tool.
