How to unfold surfaces of existing body, not sheet metal
alacrad
Observer Observer
alacrad
Observer
Observer
I wanted to get a DWG file for calculating and making kerf cuts in plywood
kacper.suchomski
Hi
You need to design plywood elements in a sheet metal environment.
Kacper Suchomski
jhackney1972
If the body or component contains a single curve, not compound, you can use the method outlined in this Blog Article and Video.  If you attache your model I will give it a try.
John Hackney, Retired
