unable to view the results in the simulation report
admin3M2RK
admin3M2RK
Community Visitor
Community Visitor
Autodesk Fusion Update 2603.1.52,
The above is the version with which i'm facing an issue of unable to view the results of the simulation report generated. Able to view upto the load cases but after that all the results like Stress, Displacement, Strain, etc were missing upon generating the report.
@CGBenner @seth.madore
dsouzasujay
Hi @admin3M2RK ,
Can you please attach previous designs that you've completed in Fusion with simulation boundary conditions?
Please export your design as a *.f3d/*.f3z file to your local drive and then attach it to your reply.
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
