How to unbend Step file for flat DXF
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
We received a job for a piece that will be cut out of plastic, and then put in a hot bend fixture to give it a radius. The file i received is of the part after it is molded. Is there a way i can unbend this so i can cut the flat file? I see how to cast a shadow for a dxf, but that obviously will not be the correct size once we bend it. I have tried it on Inventor and it seemed to maybe work, but it does not seem to be accurate. Thank you.
