How to turn the origin
Message 1 of 24
Dear all,
could someone explain please how I can set the angle of the origin so that it is equal to the sketch itselft?
That would be really great!
Thank you so much for all your comments!
Best regards,
Sven
Replies (23)
Message 22 of 24
@Brady_FultonThank you!
Message 23 of 24
Dear all,
the solution for my problem was completly different. The reason were different messearing units in F360 and my control software WinPCnc. In F360 I use as measuring unit mm/min in WinPCnc was mm/sek adjusted. After I adjusted mm/min also in WinPcnc everything worked fine.
Thank you for all the comments again and best regards,
Sven
Message 24 of 24
daniel_lyall
@Anonymous mark your last post as solved you supplied the answer Smiley Happy
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
