How to turn the origin
Message 1 of 24
Dear all,
could someone explain please how I can set the angle of the origin so that it is equal to the sketch itselft?
That would be really great!
Thank you so much for all your comments!
Best regards,
Sven
Replies (23)
Message 2 of 24
SaeedHamza
I don' think it's available yet to move the origin, I guess the reason is that there isn't any need to, since you can sketch where ever you want, and you can create as much construction planes as you want and wherever you want
Regards
Saeed
Saeed Hamza
Message 3 of 24
Hey SaeedHamza,
ok, thank you for your answer!
Doesn´t have these angle any influence on the routing process?
Best regards,
Sven
Message 4 of 24
SaeedHamza
I'm sorry, what angles?
Saeed Hamza
Message 5 of 24
The angle between the green and blue line. In the blue line is my sketch located
Message 6 of 24
SaeedHamza
This is called the zy plane
What about it?
Could you show me where you want you're plane to be, in other words, where do you want to sketch?
Saeed
Saeed Hamza
Message 7 of 24
SaeedHamza
Watch this please to make things clearer
Saeed Hamza
Message 8 of 24
please see the picture below. As you can see the green and the blue axes doesn´t align with the sketch. I think this will produce mistakes in the routing process isen´t it?ursprung.jpg
Message 9 of 24
SaeedHamza
This looks strange ...
or it might be just the sketch plane grid appearing according to it's angle
Could you please share the file? go to file > export > .f3d and attach it to your next post
and write the name of the sketch please
Regards
Saeed
Saeed Hamza
Message 10 of 24
SaeedHamza
If this is similar to what you're having then it's how it's supposed to be
Watch this please
Regards
Saeed
Saeed Hamza
Message 11 of 24
ok, you´ll find two f3d-files in the attachement, the first file shows the wrong angle of the zyx coordinate => Ansaugstutzen v8
in the second file (=>Ansaugstutzen neu) I did a new sketch so that the sketch align with the zyx coordinate. But as before I got mistakes in the routing process, for example see plaeseIMG_8227.JPG the picture in the attachement.
Message 12 of 24
SaeedHamza
I guess this is all a matter of CAM environment thing, you should have said something about it my friend 🙂
Anyway, I'm not really fully familiar with this environment so others might help.
@jeff_strater
Could you please take a look, because if CAM can't change the origin location, this might be a bug.
I recommend you post this in the CAM forums, you'll probably get a much faster answer there
Best of luck
Saeed
Saeed Hamza
Message 13 of 24
okay, thank you very much for your assistence!
Best regards
Sven
Message 14 of 24
Beyondforce
Hey @Anonymous,
Have you tried this: https://www.youtube.com/watch?v=v6DzhcG3LNs
Cheers / Ben
Check out my YouTube channel: Fusion 360: NewbiesPlus
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
Message 15 of 24
etfrench
It is not necessary to change the origin or change the sketch plane in order to machine these parts.  You do need to use the correct settings in your setup.  I'll make a video of the changes needed in a little while.
ETFrench
Message 16 of 24
etfrench
Here's the screencast.
It took at least 10 times longer to find all of the strange settings than it would have to just create two new toolpaths. Smiley Happy
ETFrench
Message 17 of 24
Hi etfrench,
thank you so much! I really can imagine that it would be more efficient to create two new toolpaths. But with your video I learn a lot more! Smiley Very Happy
What I didn´t understand is that the simulation of the milling process looks all the time good. No mistakes wasn´t shown. Do you know why?
Best regards,
Sven
Message 18 of 24
etfrench
At 6:53 in the screencast you can see the tool is cutting on the wrong side of the selected contour.  I'm not sure why the red arrows were pointing the same direction on the two end parts as on the others.  The simulation showed they weren't correct.
The CAM module is really good compared to others, but it does take time to learn how to get the best tool paths and what the limits of your machine are.  I have quite a few broken tool bits to show for my learning curve.  Smiley Happy
ETFrench
Message 19 of 24
@Beyondforcethank you as well for this usefull advice! This really makes it easier 🙂
Best regards,
Sven
Message 20 of 24
@etfrenchone another question, which tool do you use to record screencasts?
Best regards,
Sven
