Hi Bradon,
To display the center of mass
- In the Inspect drop-down, click Center of Mass.
- Select components or solid bodies to be included in the center of mass calculation.
- Click OK. Click to select the center of mass to display its coordinates in the global coordinate system.
To delete the center of mass
- Expand the Analysis folder in the browser.
- Right-click the desired center of mass, and click Delete.
To show or hide the center of mass
Hide the center of mass to exclude it from other model calculations.
- Right-click the desired center of mass, and click Hide/Show.
To measure from center of mass to other objects in your design
You can measure the distance from the center of mass to other objects in your design - edges, faces, other center of mass, for example. Click Measure from the Inspect drop-down, and select the desired objects to measure their distance.
KRISHNANUNNI K U
B.arch, M.Des Industrial Design Student.
