How to turn on Center of Mass?
brandon5569
brandon5569
I would like to turn on Center of Mass feature.  I used this feature once in the past by accident.  I can not figure it out for the life of me please help.
Brandon
krishh0007
Hi Bradon,
To display the center of mass
  1. In the Inspect drop-down, click Center of Mass.
  2. Select components or solid bodies to be included in the center of mass calculation.
  3. Click OK. Click to select the center of mass to display its coordinates in the global coordinate system.
To delete the center of mass
  1. Expand the Analysis folder in the browser.
  2. Right-click the desired center of mass, and click Delete.
To show or hide the center of mass
Hide the center of mass to exclude it from other model calculations.
  2. Right-click the desired center of mass, and click Hide/Show.
To measure from center of mass to other objects in your design
You can measure the distance from the center of mass to other objects in your design - edges, faces, other center of mass, for example. Click Measure from the Inspect drop-down, and select the desired objects to measure their distance.
KRISHNANUNNI K U
B.arch, M.Des Industrial Design Student.
I'd love to have the ability to add it to the 2D drawings
