Message 1 of 9
11:08 AM
There are times when I want to use the push/pull tool to change the diameter of a hole or thickness of a wall. However, I am only able to see the change in distance of the surface being pushed or pulled. I want to be able to see the total diameter of the hole or thickness of a wall as I am changing it. Is there a way to do this? Such as adding a reference dimension to model geometry that changes with the geometry?
