- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello Fusion forum.
Now in about the thirtieth hour of diligently following tutorials
by running the tutorial on the iPad while the steps are followed exactly
on the PC with the F360 app running. The tutorials are repeated
over and over because the instructor says something like
'use the mouse to increase the dimension' when what is meant
is 'press down on the mouse wheel and move the mouse wheel while it
is pressed down.' So the process must be repeated until the correct
process is stumbled upon. Painstaking and tedious.
But a great deal has been learned.
However, the assumption is that by following the tutorial, that the knowledge
needed to create a model, which is quite different from model in the tutorial,
will be happened upon or extrapolated from the method used to create the tutorial model.
So please forgive some basic questions to get me off high center and move
along.
The context is that the part that is needed is shown in the attached
drawing marked Staircase LED Fixture Double Receiver.
The socket bottom and the round body above the socket have been
sketched and extruded in F360 and is marked Socket Bottom
and Round Body.
It is hoped that it is ok to ask more than one question in a forum
post. If it is not, I will withdraw this post and separate the questions.
1. Can it be known if the Round body sits on the top plane or the bottom
plane of the Socket bottom. If so, how can this be determined?
2. Should the Socket bottom and Round body be separate Components
or separate bodies? (Most of the advanced features of F360 like
movement studies, joints, injection mold simulation and collaberation
are not needed.)
Is the method for joining Bodies different from joining Components?
3. Are Components and Bodies created and then joined or joined as they are created?
4. The next step is to add the Lens plate. Should the Lens plate be begun
as a Body or Component? Can Components be begun as a Sketch or can
only Bodies be begun as a Sketch?
5. Is there knowledge of any type of interactive class or instruction,
even if it was a talking head that would allow queries at a specific, limited time?
I have resources and am willing to patiently go through the tutorials
but quite often a tutorial is followed that has little or nothing to do
with goals that are the challenge.
Thanks.
Allen Pitts
@jhackney1972
@laughingcreek
