How to stretch an object at a plane that intersects?
gregVUG8E
Message 1 of 15
gregVUG8E
Is there a way to define a plane that cuts through an object, then then stretch the object out either side of the plane?  Kind of like extruding the object either side of the plane based on the shape defined where the plane cuts through the object…
Replies (14)
Message 2 of 15
davebYYPCU
Is there a way to define a plane that cuts through an object, Yes
then stretch the object out either side of the plane?  Only in some circumstances
You can harvest the cross section of the object, into the sketch on that plane, then Extrude > 2 sides / symmetric.
Might help.....
Message 3 of 15
jhackney1972
Take a look at the Screencast and see if this process helps you out.  The object, being cut here, is very simple but it can be more complex, the process is the same.
John Hackney, Retired
Message 4 of 15
TheCADWhisperer
Message 5 of 15
gregVUG8E
thanks - this seemed to do the trick but noting I had to manually "split body" and move the two portions aparts and move them apart before extruding....unless there was a way to do this in one step after doing the cross section analysis?  (i.e. move & extrude in one go)
Message 6 of 15
davebYYPCU
A few ways to do it, but without seeing your "profile / object"
Just make it longer.  In John's cylinder - a longer cylinder without the high jumps?
cut - move - extrude,
Move face - Press Pull etc.
Might help.....
Message 7 of 15
jhackney1972
Take another look at my Screencast.  I did not have to Split Body, I just used the Slice function from the Sketch Panel.
Message 8 of 15
davebYYPCU
Sounds like he won't need a sketch.
Message 9 of 15
jhackney1972
I think he will with my method as he needs to use the Intersect Tool to get the profile, and the Slice function makes it easier.
Message 10 of 15
davebYYPCU
he says ....  and move them apart before extruding
the face - won't need the sketch
Message 11 of 15
jhackney1972
For some reason, which he did not share, he is doing a Split body, and moving them apart before he does the sketch, intersect and extrude.  Got me because the Split Body and moving apart was never in the original descriptive need.
Message 12 of 15
davebYYPCU
He said,  ...Stretch.
So I see it as I have a Y mm long object that needs to be  ( X mm longer....)
I did not see mention of an inclined plane,
but until he reads message 4 in here, its just circles
Message 13 of 15
jhackney1972
He wrote: "Is there a way to define a plane that cuts through an object, then then stretch the object out either side of the plane?  Kind of like extruding the object either side of the plane based on the shape defined where the plane cuts through the object…"
I think he used the word "stretch" in the same way we would say "extrude" but that is my interpretation.  If he comes back and asks for something different, then we can accommodate him.  You know how vague and "read my mind" questions are on the forum.
Message 14 of 15
davebYYPCU
My mind has a thing like this, and the stretch inner cylinder is the question.
Hence my answer in message 2, in some circumstances
Might help....
Message 15 of 15
gregVUG8E
Hi guys - just checking back in - thanks for the help.  Yes I used "stretch" without knowing the best term to use.  I've had a chance to try things and both the cut/move/extrude and sketch/analyse approches seem to work, so all good.
I guess overall I was trying to understand whether there is a two step "cut/stretch" approach rather than a "cut/move/extrude" approach for example, but not a big deal I guess.
