How to split a big part to cut on small CNC router in many panels?
zetkasprzyk
Message 1 of 28
zetkasprzyk
Great minds of Fusion 360!
I would like to cut out a big shape ( tree ) on my small CNC router. This shape is roughtly 160cm tall, 180cm wide and router's bed is only 30cm x 40cm . How can I split the design ( model ) into  many "panels" so i can  cut them in 30cm x 40cm MDF material and glue them togheder later, with edges that roughtly match in size ( taking the cutter diameter into account ) ?
Thank you in advance for any ideas and answers.
Replies (27)
Message 21 of 28
etfrench
Well done. That looks really nice.
ETFrench
Message 22 of 28
etfrench,
I have one more question for you.  how do I put the attached file flat either on the X or Y axis to get ready for milling?   I have a number of these that are standing on the Z axis and need to put them flat?  again, sorry for the basic question.
thanks for the help!  can I buy you a coffee?
Message 23 of 28
etfrench
The simplest if you're doing one at a time is to set Z and X in the Manufacturing Setup.  If you're doing several at the same time, then I would make a copy of each in a new component (labeled CAM). Use a Planar joint to arrange them.
You could also use Nesting which was introduced several updates ago.
ETFrench
Message 24 of 28
etfrench
Like this:
ETFrench
Message 25 of 28
thanks!  this worked.  been trying to get multiple done with the planar joint option.  will keep you posted.
Message 26 of 28
Sorry to keep bothering etfrench.  I am still struggling with the planar joint.  could you kindly explain using the attached file if you have the time?
Message 27 of 28
etfrench
Here's a screencast showing planar joints.
ETFrench
Message 28 of 28
thank you! thank you! and thank you for the help once again!
can I buy you coffee?
