Hi, I found this tutorial online and wanted to try myself to find a solution using the regular thread tool.
For that I first tried to cut off the tread off the main body, but this leaves me with an error, when I used this selected face as cutting tool.
So I designed a split tool with a surface extrude, but this also gives me the same error.
Do you have a solution for that?
Hannes
Solved by g-andresen. Go to Solution.
