How to show dimensions on a 3D model
eyadserry
Message 1 of 11
eyadserry
Hey,
I designed this desk,
 but I want to make the dimensions visible—something like this.
Is this available in Fusion? If not, how do you suggest doing it?
Replies (10)
Message 2 of 11
jhackney1972
Dimensions, in Prospective View are not available in the 2D Drawing Environment.  I cannot give any Fusion based suggestions.
John Hackney, Retired
Message 3 of 11
jeff_strater
my recommendation would be:  In the Design workspace, create a few sketches, project geometry into those sketches, and add (driven) dimensions.  Not pretty, but it would make it possible to show those dimensions.
Jeff Strater
Engineering Director
Message 4 of 11
Drewpan
While it is not really possible to do what you want in the Design model
environment, other than the possible suggestions already mentioned. It
may be worthwhile doing this in the actual Drawing environment that is
set up for this sort of thing.
The Drawing environment is for creating engineering drawings and allow
you to import a View of the model as shown , and then create the usual
Top, Front and Side views with all of the measurements and dimensions.
There are some good embedded tutorials in the Documentation showing
you the basics and then it is a matter of playing around until you get
something suitable for your needs.
Cheers
Andrew
Message 5 of 11
eyadserry
when I add to a drawing it appears pixelized.
Message 6 of 11
Drewpan
I would check the graphics settings as the model should not be pixelated in any way.
It should look exactly like the model in the Design space since that is what it is based
upon. You can find graphics settings in the Preferences tab.
Cheers
Andrew
Message 7 of 11
eyadserry
Could you help me ?
Message 8 of 11
g-andresen
There are special applications for technical illustration, such as something from Corel Draw.
günther
Message 9 of 11
Drewpan
Most commonly it simply involves resetting the graphics driver. If it is Auto then select OpenGL
This will sometimes fix it on its own or sometimes you will need to restart fusion. Sometimes
you need to restart and set it back to what it originally was. This will most often fix it. If it
persists then you might need more professional help. The Devs will monitor for this sort of thing
and contact you if they can help.
Cheers
Andrew
Message 10 of 11
eyadserry
It somewhat solved it, This solved the pixelation but the object came out blue color.
Message 11 of 11
TheCADWhisperer
@g-andresen
Can stay within the Autodesk ecosystem and do this in Autodesk Inventor Professional.
