How to set up a parameter specifying 'No Units'
I am trying to create a parameter that will be a percentage of the size of another parameter. If I specify 'No Units' the 'OK' button is not accessible.parameter 01.jpgIf I now specify the Units I get an error:
Accepted solutions (3)
jhackney1972
You are mixing Units.  The parameter "length" has an assigned unit of "mm" and you are try to change it to "No Units" in your formula.  Take a look at the two user parameters I created, both are 50 percent of the value, one is "No Units" and one is "mm".  Keep your units constant.
John Hackney, Retired
laughingcreek
you can strip the units out by dividing by mm
Thanks a lot Laughingcreek. Works great now.
Seems a little quirky, but I get it.
Thanks JHackney1972. I appreciate your response.
