How to set Max/Min in the legend range on Autodesk Fusion 360 new update
pingk33
pingk33
Community Visitor
Community Visitor
The result is very low, so I want to change Max = 1 Min = 0
dsouzasujay
Hi @pingk33 ,
Displacement results are based on the units used. Could you try changing the units to see if it helps you visualize the results better?
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
