- Mute
- Permalink
- Report
I'm trying to model a CNC waste board with replaceable MDF slats that will be surfaced flat by the CNC. These slats are fastened by M5 hex cap bolts. I'm trying to use the hole tool to make a counterbore clearance hole, but I need a custom counterbore depth. The idea is to keep the max amount of material above the head of the bolt to maximize the number of resurfacings that can be done. I'm trying to use the hole tool instead of circles in a sketch so Fusion will calculate the clearance diameter for a M5 bolt for me instead of me doing it.
When I use the hold tool and specify a flat bottom clearance counterbore hole and set the fastener to M5 socket head cap screw the option to change the counterbore depth is greyed out and can't be changed - is there any way to "unlock" that setting?
