How to separate a sketch in two parts
Hi all guys, I'm new to the forum and I have just started using Fusion 360, it is a very interesting program as regards the creation of objects that need precise measurements. these days I have encountered a problem, I uploaded a 2d image on which to make a sketch, made without too many problems using dimensions and constraints. but now I have a problem that I can't solve ... I would like to physically separate the sketch I made into two parts, I will give an example ... I have an oval sketch and I have to separate it into two distinct parts not for come on in half, how do i do it? thank you all
g-andresen
What do you want to achieve or to do with it?
Please show it in screenshot.
günther
TheCADWhisperer
File>Export and then Attach your *.f3d file here.
Here
through the link find a draft drawing of the oval that I would like to separate in half to get two sketches from one.
g-andresen
Hi Andrea,
Just use the Break command*.
günther
*No guarantee, because I don't know the sketch!
I try and let you know, otherwise another person had recommended me a more Spartan method, copy and paste and then delete what I don't need ...
