Multiple Motion Links
Hi everyone,
Is there a way to move a project with multiple motion links?
I need to move surfaces with two motion links at the same time. Is that possible?
Thank you in advance.
jeff_strater
yes, absolutely it is possible.  You can relate any two joints with a Motion Link, and can have as many Motion Links as you want in your design.  Of course, at some point, the performance will get unacceptable, but I just created a design this week for another thread that has 7 Motion Links in it (attached)
Jeff Strater
Engineering Director
Yes, in my project there are many joint, but my question is if I can move both motion links at the same time. Is it possible? Thank you!
jeff_strater
yes, see this screencast of the design I shared here.  The motion is generated just from dragging one of the panels - all Motion Links are active at the same time.
Jeff Strater
caterinaansalone
Come fai a non farli bloccare? Sto lavorando ad un file con molti giunti di rivoluzione collegati nel movimento ma ad un certo punto il programma rende la struttura rigida bloccando i movimenti.
davebYYPCU
Double check alignment of the jointed parts.
Change one Revolute to Cylindrical, if it works, you have alignment error.
Might help….
