How to save rendered view
nkloski
nkloski
Hopefully this is something obvious that I am missing:  I did a cloud render, but I cannot see any way to save that render to my hard drive.  I clicked on the render, and a little window popped up, but there is only a "re-render" button and not any option to save.  Right clicking does not work......the cloud render completed successfully, but I can't find where to download it!
Thanks!
Nick Kloski
Hello nkloski. Your case maybe a bug. Cloud render in my software works well (such as in image below)
Cloud render
Why dont you try to use local render? Maybe that can be solution. Thanks.
By the way, can you help me to give the "Like" to my design in the links below?:
1. https://fusion360.autodesk.com/projects/kujang
2. https://fusion360.autodesk.com/projects/akik-indonesian-gemstone
3. https://fusion360.autodesk.com/projects/delman-style-lounge-chair
I am participating in Autodesk Fusion 360 Competition in Indonesia and need 50 "like" for each project to be judges by juries. Thank you very much! Enjoy the day!
Best regards,
Arif
nkloski
Ah, for some reason this morning, now I see thew download button! (I couldn't use the local render because I needed a resolution that was higher than my monitor resolution for use in a print publication.
And, great designs! I did indeed click the like button!
Nick Kloski
Great that the cloud render is working properly!
Thanks nkloski for like!
Arif
martin
Pressing the download button does not save the render on one file only. All other renderings have saved. Local rendering used.  Any ideas?
