Insulation materials
Monodon
Monodon
I am currently working on a design including several different insulation materials - a.o. mineral wool, PUR foams, foamed HDPE, and multilayer PET shielding covered with aluminum foil layer. How to implement my materials to use them in Fusion360 ? Is it possible to create my own materials ? How ? What parameters can I describe ?
Maciej
Hello Monodon, I hope this link below can help you:
A. Create material
Link: http://fusion360.autodesk.com/learning/learning.html?caaskey=caas/CloudHelp/cloudhelp/ENU/Fusion-Fun...
B. How to implement material to body or component
Link: http://fusion360.autodesk.com/learning/learning.html?caaskey=caas/CloudHelp/cloudhelp/ENU/Fusion-For...
Additional info:
Fusion 360: make a materials template to insert
http://fusion360.autodesk.com/learning/learning.html?caaskey=caas/screencast/Main/Details/c4361e12-4...
By the way, can you help me to give the "Like" to my design in the links below?:
1. https://fusion360.autodesk.com/projects/kujang
2. https://fusion360.autodesk.com/projects/akik-indonesian-gemstone
3. https://fusion360.autodesk.com/projects/delman-style-lounge-chair
I am participating in Autodesk Fusion 360 Competition in Indonesia and need 50 "like" for each project to be judges by juries. Thank you very much! Enjoy the day!
Best regards,
Arif
Create material
1. Manage Material
2. Material Browser
Best regards,
Arif
Monodon
thank you for your email but this is not what I am asking for - I need to create a completely new material and define its parameters.
Pozdrawiam/Med venlig hilsen/Best regards/Mit besten Grüßen/ С уважением/Inussiarnersumik inuulluaqqusillunga/
Maciej Buzuk, PhD. Eng,
Sworn Expert of KIGM
Advisor to Polish Standardisation Commitee - (Polski Komitet Normalizacyjny)
Member of PSE
Member of IAMG
Monodon Sp. z o.o.
PL- 81-524 Gdynia,
Balladyny 20
Poland
Mobile: +48 517 919 672
Phone: +48 503 182 113
Fax: +48 58 739 10 23
Skype: maciej_hermes_lab
E-mail: maciej_buzuk@icloud.com
ISO 9001 ∣ ISO14001 ∣ ISO 18001 ∣ ISO 29001 ∣ ISO 27001
WE PROMOTE AND USE LCA: ISO 14040 and 14044
Niniejsza wiadomość jest przeznaczona wyłącznie dla osoby lub podmiotu, do którego została zaadresowana i może zawierać treść o charakterze poufnym lub zastrzeżonym. Odbiorca wiadomości, który otrzymał ja omyłkowo, proszony jest o zawiadomienie nadawcy i usuniecie tej korespondencji. Rozpowszechnianie, przekazywanie lub kopiowanie tej wiadomości jest zabronione.
Confidentiality Note: This message is intended only for use of the individual or entity to which it is addressed, and may contain information that is privileged or confidential. If you are not the intended recipient, please notify the sender and delete this message. Any dissemination, distribution or copying of this communication is strictly prohibited.
promm
@Monodon,
What @Anonymous suggested is the right workflow.  What you need to do next after you have created the new material as he had shown is edit the new material.  As you see in the image below the material editor allows you to change the material properties.
Let me know if this provides the workflow you are looking for.
Cheers,
Mike Prom
