How to save in personal computer instead of cloud?
Message 1 of 8
when I am saving my files.  It is saving directly to cloud folders.  I am interested to save in my folder too.  Could any one help in this problem?
-Ranjith
Replies (7)
Message 2 of 8
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
Welcome to the Fusion 360 Community!
You can export the fusion file directly to your computer by going to File->Export and then selecting the directory you wish to save to as well as changing the file type to Fusion archive (this is a fusion native file format). This will only work if there are no linked components (externally referenced) inside your model. If it is, you will have to follow the same workflow on your A360 site. A better walkthrough can be found in this guide here!
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
Message 3 of 8
Thank you
Message 4 of 8
Hi ranjith.263,
                      You can even download the file directly from a360.autodesk.com in any of the provided format. Through this method you can download your file from anywhere.
                         I hope it solves your problem.
Regards
Mandeep
Message 5 of 8
davv_jht
Community Visitor
Community Visitor
None of the above it possible any more.
Message 6 of 8
jhackney1972
I used the process outlined in Message #2 three times today.  I would suggest you ready it closely again and try once again.  Please note the process will not work on assemblies containing Linked (external) files as outlined in the message.  I suggest you use a very simple model to practice the process.
John Hackney, Retired
Message 7 of 8
monicag.smith
Observer
Observer
why am I not able to save a file to my desktop in Fusion 360. When I go to save as, name the file, and choose location, the desktop is not an option.
Message 8 of 8
g-andresen
"Export" will do
günther
