How to return to sketch object dialogue box?
r.moss
Message 1 of 10
r.moss
Sorry for a really basic query - I'm just learning Fusion 360, having previously used SolidWorks from time to time.  One thing I find strange is that I cannot return to a command to change the parameters.  The tutorial videos assume you "get it right first time" - what if you don't?
For instance, here I am creating a pattern of arcs in a sketch:
Having created the pattern, suppose I want to modify it (change spacing, number of instances etc)?
It seems logical to right-click on one of the patterned features, but none of the pop-up options take me back to this dialogue box:
"Repeat rectangular pattern" generates a whole new pattern rather than editing the existing one.  I have tried right-clicking on the timeline too:
Help!
Thanks.
Roger
Replies (9)
Message 2 of 10
g-andresen
Hi Roger,
that´s how it works.
günther
Message 3 of 10
r.moss
Hi, thanks, somehow it works for you but when I right-click I get a different set of menus:
Going through to the "Sketch" options doesn't help either:
Maybe I have a different version?  Mine is 2.0.3803, Fusion 360 Ultimate, Student.
Roger
Message 4 of 10
TheCADWhisperer
Same as in SolidWorks - it is almost always better to pattern Feature rather than Sketch element.
You have the latest version.
File>Export and then Attach your *.f3d file here.
Message 5 of 10
r.moss
After playing around a bit more, I've found a work-around.
I can get your right-click menus if I only have one sketch object (the circle):
If however I have more than one sketch object (e.g. a line and a pattern of circles) then I don't get the "Edit rectangular pattern" menu, instead I get this:
I would call this a bug - I see from comments in previous posts that people find it very disconcerting if a program behaves differently depending on the circumstances.  One keeps thinking: "I'm sure I've managed this before....how did I do it?...why won't it work now?"
The work-around is to use the Modify/Change parameters menu:
Then change the spacing, count etc as desired:
Happiness at last!
Roger
Message 6 of 10
r.moss
Thanks.  Yes, with hindsight patterning the arc features would have been better (I wanted to put them around a curve - hadn't realised there is a useful "Path pattern" option to do this).
Interestingly, if I try "Modify/Change parameters" on my sketch the dialogue box shows one pattern but actually there are two (vertical with 2 instances, horizontal with 6 instances) so there should be "Pattern1" and "Pattern2"...maybe a bug?
Message 7 of 10
g-andresen
you have to click the pattern symbol, not the sketch elements!
günther
Message 8 of 10
r.moss
Ah!  Yes, that was what I thought I was doing.  Actually you have to left-click the pattern symbol to select it, then right-click it.
Thanks very much.
About patterning features/bodies instead of sketch elements: I am trying to draw a pattern of holes with bosses around them:
I tried making the bosses with an extruded cut down the middle, but of course the main slab fills them back in.   So now I have a pattern of bosses (bodies) and a pattern of holes (faces).  This works well enough, but it seems inelegant to use two patterns, with the same count and spacing for each.  Is there a better way?
Thanks for all your help
Roger
Message 9 of 10
chrisplyler
Message 10 of 10
r.moss
Thanks very much!
Roger
