- Mute
- Permalink
- Report
OK guys I'm trying to create this little design and as you can see it is a 45 pound weight lifting plate. I have to create multiple other plates but in different values that are size differently. An example is that this 45 pound plate is 40 mm around the outside. The 25 pound plate will be 24.8 mm, the 10 pound plate will be 20.4 mm and the 5 pound plate will be 16 mm. All of these are outside dimensions. The question here is I've got the 45 pound plate designed the way I like it (as you can see sketch five is not fully constraint), I was hoping that I could just change the outside dimension of the 45 pound plate (which is 40 mm) and that would size everything accordingly down to the proper size for the next plate. Well, that's not working exactly the way I want hence hopefully that's where you guys come in and can point out my errors. The goal here is to get the 45 pound plate drawing to be fully constrained or I could just change one or two settings and everything will size accordingly. Also noticed that I have text that would also be nice to have that size accordingly as well. Any help would be appreciated. Please see attached files.
