Fusion 360 Thermal Simulation
manuel5588
manuel5588
I'm working on a thermal simulation with a constant temperature heat source. I also applied convection and radiation conditions. I place a body around the product components to represent a volume of air around the device.
To me, it appears that the heat is moving away from the heat source and then moves laterally once the outer surface of the air mass is reached. I would have thought the outer surface of the body would not affect the movement of heat. I might be missing a boundary condition. Is there any recommendations on how to run the simulation differently or maybe comments if the simulation is working as expected?
I have tried making the air mass larger but the simulation doesn't complete for mess errors. I also think that making a larger air mass body won't help because the steady state simulation will run longer as it heats up a larger air volume. I would optimally be able to see the different steps in the simulation but Fusion doesn't have that feature or ability to set a time limit.
henderh
Hi @manuel5588,
Thank you for providing the images of the simulation results. For accurate heat transfer simulation through air, we offer a specialized study type that is catered towards Electronics Cooling physics that should be closer to a real-life simulation:
  • https://help.autodesk.com/view/fusion360/ENU/?guid=SIM-E-COOLING-SDY-CONCEPT
    • Fluid domain in electronics cooling
      • When you switch to the Simulation workspace and select an electronics cooling study, the software creates the fluid domain that represents the air, in and around the model and its parts, automatically for you. The external environment allows both for natural convection to occur around the device, and for the free flow of air for proper cooling.
As you've noticed the results are the steady-state in thermal study types, and the same is true for E-cooling. If you require transient results, I believe that Autodesk CFD has what you're after:
I hope this helps! Please let us know if you have any additional questions, comments, or suggestions.
Hugh Henderson
QA Engineer (Fusion Simulation)
