How to remodel sofa nodes?
Hi
I try to remodel sofa nodes as picture below:
I create a box in Form mode, then I move vertex. now, How can I add more detail of nodes as picture?
Johnc911
This is the general idea.
TrippyLighting
you'll simply need more geometry. Unfortunately this can get pretty tedious in Fusion 360 with designs like a sofa.
Hi  Johnc911
Great idea. I use Subdivide and rotate face to add more details
Best regards
Travis
Hi Peter,
I think John's idea is better in this case. How can I subdivide as picture below?
Best regards,
Travis
TrippyLighting
Johns screencast shows one technique. As it did not make much sense to create a screencast showing the same technique my screencast shows another. Both can be combined. This isn't a case of one is better than the other 😉
The way you are modeling it is very easy to create self-intersecting geometry and if you start subdividing the way you do it you'll end up with a very heavy model. As a beginner you should model in quads only. Most experienced Sub-D modelers model 80%in box view mode and check in smooth-view mode. Not the other way around.
