Message 1 of 10
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I made a change to my skecth, how do I get the model to be recalculated?
Best regards.
Best regards.
Normally the update will happen automatically after you leave the sketch. You can force an update by selecting this indicated command.
John Hackney, Retired
If you attached your model to your Forum post, it did not make it. You cannot attach files using email, they must be attached using the Forum Attachment section.
Yes, your model has been updated. It is hard to measure the cone large diameter due to the applied fillet. Simply suppress it and then measure.
By the way, I question all the moves in your model. You need to model around the origin and join components together using Joints.
Edit: I cleaned up your model, it is attached.
You obviously have not watched my supplied Screencast. In the Screencast I suppress the edge fillet and show that your large OD is 133mm. The Fillet rounds the edge and makes the OD smaller.
My mystake. I didn't go back to the forum to view your entire reply. In my next model I'll avoid all the moves and stick to the origin. I'm a beginner with Fusion 360.
Many thanks and best regards.
