How to recalculate a model
gillesht
Message 1 of 10
gillesht
I made a change to my skecth, how do I get the model to be recalculated?
Best regards.
Replies (9)
Message 2 of 10
mango.freund
if you have your history "timeline" turned on, move the cursor to the beginning and start like a movie. watch out for all yellow sketches and red warnings. BR mango
Message 3 of 10
jhackney1972
Normally the update will happen automatically after you leave the sketch.  You can force an update by selecting this indicated command.
John Hackney, Retired
Message 4 of 10
gillesht
I ran construction timeline but Im trying to measure the new diameter of the base of the lamp shade without success. So I’m not sure of the result. The diameter should be 133 mm. I’m sending you my model. If you could confirm that the recalculate was done, it would be greatly appréciâted.
Best regards.
Message 5 of 10
jhackney1972
If you attached your model to your Forum post, it did not make it.  You cannot attach files using email, they must be attached using the Forum Attachment section.
Message 6 of 10
gillesht
Attach is the model.
Best regards.
Message 7 of 10
jhackney1972
Yes, your model has been updated.  It is hard to measure the cone large diameter due to the applied fillet.  Simply suppress it and then measure.
By the way, I question all the moves in your model.  You need to model around the origin and join components together using Joints.
Edit: I cleaned up your model, it is attached.
Message 8 of 10
gillesht
I measure the large diameter and I get 130 mm. I’ve modified the sketch to have 133 mm. I don’t understand how the model was updated.
Best regards.
Message 9 of 10
jhackney1972
You obviously have not watched my supplied Screencast.  In the Screencast I suppress the edge fillet and show that your large OD is 133mm.  The Fillet rounds the edge and makes the OD smaller.
Message 10 of 10
gillesht
My mystake. I didn't go back to the forum to view your entire reply. In my next model I'll avoid all the moves and stick to the origin. I'm a beginner with Fusion 360.
Many thanks and best regards.
