how to "Non-Uniform Scale" 3 connected bodies for 3d printing?
maker9876
Message 1 of 10
maker9876
I have three bodies which will be aligned in the Slicer such that when they are 3d printed (each with different perimeter/infill settings) they will form a single part.
According to the characteristics of my printer/material (ABS) I need to increase the size of the part by 0.9% in the XY directions and 0.4% in the Z
It is clear how to use the Non-Uniform Scaling dialogue box to set the scaling, BUT HOW TO CHOOSE THE POINT ABOUT WHICH TO SCALE?
I don't understand the consequences of point selection, but can see that there are some. Should I scale each of the three bodies separately (about their own respective points)? Or scale them all at the same time about a single point?
Replies (9)
Message 2 of 10
g-andresen
You need to scale each body separately.
günther
Message 3 of 10
maker9876
Thanks!
How do I choose a point on each body when I scale it?
Message 4 of 10
g-andresen
scale > selct body > select point > select factor > ok
günther
Message 5 of 10
maker9876
sorry, I mean, how do I choose a point on the body? That is, on the left, on the right, at the top, in the middle or whatever?
Message 6 of 10
maker9876
can anyone explain how to choose a "point" when performing non-uniform scaling? What makes one point better than another?
Message 7 of 10
g-andresen
non uniform  scale > select point
(view in My Videos)
günther
Message 8 of 10
maker9876
thanks for the video
So does that mean that it doesn't matter which point you choose, the part itself will always turn out the same larger version of itself according to the x, y, z parameters? That the only thing that changes - according to the point selected - is the POSITION IN SPACE of the resultant part?
(I've read in the forums about people desperately wanting to select the "centre of mass" of their part, but I don't quite understand why. Presumably they have a reason?)
Message 9 of 10
g-andresen
Exactly!
The reason for this is not known to me.
günther
Message 10 of 10
maker9876
Much appreciated this clarification. Now can proceed with confidence. Thanks again for your help.
