How to put holes in the back?
Hi everyone.  Complete newbie here.  I am trying to design a spoilboard for my CNC router.  From the front, it has countersunk (counterbored) holes to mount to the bed.  From the back, it has a grid of countesunk (counterbored) holes for t-nuts as a workholding/clamping system.
I start by making a sketch of the board.  Then I extrude it to the actual thickness of my board.  Then I put my "mounting" holes in the front.  My problem comes when I try to put the "clamping" holes in the back, because I can only place them, or sketch anything, on the "front" face (original sketch).  I haven't been able to figure out how to place holes, or even sketch anything, on the back face.  I'm sure this is very elementary, but I haven't been able to find any information.  Thanks in advance for any help!
TinWhisperer
  • In the design environment on the top left corner there is your navigation cube.
  • Use it to navigate to the bottom of your model
  • On the top right there will be start a new sketch click it and then click the bottom of your model.
  • This will open up a new sketch at the bottom plane of your model.
  • Use P for project to project any geometry you care to use and sketching new geometry as you like.
  • Now you can extrude this new geometry as a cut through your model
g-andresen
Please share the file.
File > export > save as f3d on local drive  > attach it to the next post.
günther
TheCADWhisperer
This might give you some ideas.
TinWhisperer
sorry got my left and right mixed up there.. too late to edit the post
Thank you for the help! I hadn't figure out how to put the new sketch on the face -- duh! The example spoilboard was also very useful.  I really appreciate the input.
