How to properly create a mirrored component?
kristofpucejdl
Message 1 of 20
kristofpucejdl
what is the best way to create a standalone component which is a mirror of another component and retains the link to the original in the timeline?
So far the best solution I found was to create a new component, insert a derive (or 'Insert into current design') of the original component, create a mirror of it, and then turn off the visibility of the original. Which felt like a dumb way to do it but worked for me until I needed to care about the weights and moments of inertia of my assembly. Now the invisible 'dummy' component throws off these measures.
I did not find a way to remove or delete the original component after the mirror command. For 'Insert Derive' the delete option is simply not there and if I start by 'Inserting of the original into the new Design', I can delete it but not 'remove' it after the mirror command in the timeline, hence I lose my mirror and break all the further timeline dependencies if I do so.
I tried the same with just the bodies of the component that I want to create a mirror of - same deal. Can't get rid of the original unless I break the link.
Any help would be much appreciated 🙂 I feel like I am missing something rather obvious here.
PS: @TrippyLighting  would you possibly have a clue, sir? I read your comments on similar topics and it seems to me you know the good practices. So just to clarify, I am not trying to mirror some assembly or anything complex. No joints, just a pretty basic component, one or two solid bodies. I do want to retain the link to the original one such that when I modify the bodies, I have the way to update the mirrored version as well.
Replies (19)
Message 2 of 20
g-andresen
Can you explain this?
Independent and yet dependent?
After mirroring you can still go back in the timeline and then edit the original component. Then the change will also take effect on the mirrored part.
If this is not what you want to achieve, take a look at the "Remove" tool.
günther
Message 3 of 20
kristofpucejdl
Hi Guenther,
thanks for the super prompt response.
What I mean by 'standalone' is that the mirrored component would be its own 'design file' in my project folder. Previously, I always used the 'mirror' tool within larger assemblies - I created a mirror of a component which was already part of the larger design file (i.e. it was in the design tree) and I immediately used (jointed, modified etc) this new mirrored version in that same design file.
But now, I would like to simply have the mirrored version of the component 'standalone', so I can import it into different larger assemblies down the road.
Like this - I have a simple component called Lower Leg Right, which I conventionally designed from sketches and solid body features:
and I need it's 'Lefty' version too 🙂 In fact, what I really want is to just mirror the bodies from the Right Leg into the Left Leg so I have the corresponding structure in both of these.
You are mentioning the 'remove' tool, but I seem to not have this accessible when I 'Insert derives' of the bodies from Right Leg into the Left Leg. I can not remove these derived bodies other than deleting the 'derive' feature from the timeline, but that obviously kills my consequent mirror 🙂
I can remove the original bodies if I first 'break the link' and turn the derives into base features, but that prevents me from updating the mirrored component (Left Leg) according to any new changes in the original component (Right Leg).
Apologies for the messy explanation, I hope I am at least somewhat clear.
Message 4 of 20
TrippyLighting
There is a workaround possible. Probably the weirdest one in Fusion 360 😉
Derive the bodies from your original design into a new component.
In that new component create a user parameter, say, "scaling_factor". Make it unitless and set it to "1".
Now scale the 2 bodies non-uniformly and use the user paramer to st the scaling factor in the mirror direction.
Now in the user parameter dialogue change the value of "scaling_factor" to "-1".
Voilá. Mirrored geometry in a new external component and nothing to remove.
This will update properly if you change the component in the originating assembly design.
I can create a screencast later if this isn't clear.
Message 5 of 20
kristofpucejdl
I did not see that coming!! 😄
Works like charm, no problems following that explanation. Thank you very much!
(I almost feel stupid not to think of non-uniform scale as an option. It does make sense now that you enlighted me)
Much to learn... 🙂 Thx again!
Message 6 of 20
TrippyLighting
Please don't feel stupid!
Even if you had thought of it, the real stumbling block is that the scaling tool does not accept negative values either when typed into the field when creating or editing the scaling factor.
If you start this process by setting the "scaling_Factor" user parameter to -1, the scaling UI does not accept that either. You'll have to set it to a positive value first, then scale and then change the user parameter to the negative value.
Message 7 of 20
kristofpucejdl
Oh, ok. Well, the more kudos to you knowing about it. I had my hopes right when I tagged you 😉
I am no one to judge how difficult would it be to unlock the negative scaling options through the dialogue, but it seems like it would make the transform much more useful. Anyway, this allowed me to move forward so I am more than happy 😄
Message 8 of 20
johnTMLEN
Observer
Observer
What is entered into the expression box to link the two together?  Thanks!
Message 9 of 20
TrippyLighting
I don't understand your question.
Message 10 of 20
johnTMLEN
Observer
Observer
I am trying to create the same idea: create a separate mirror component. I
just don't understand what is required in each box of the user parameter to
make this happen.
Message 11 of 20
TrippyLighting
I described the workflow in detail in post 4.
Message 12 of 20
John_Wright
Just to jump on this with "weird work arounds"........this might well work for what you want, or just a different thought process.
If you want to "remove" a derived body from a file you do the with the steps detailed below.
derive the component into a new file
Extrude a piece of geometry as a "NEW BODY" that is enveloped by the derived part
"Combine" the new body as a "join" with the "Target" being your new body and the "tool bodies" being the derived part. - Do not click keep tools.
You can then mirror that body
The old body can then be removed without the issue of "cannot removed derived bodies"
Message 13 of 20
SA_01
Observer
Observer
Had the same issue and used the scaling factor solution to solve it. Still works!
Message 14 of 20
agmlauncher
Same here. You don't have to apply the scaling factor before deriving. Scaling of the derived component is an operation that has no backwards link to the original component.
So what I did was this:
1. Create the reference component as normal
2. Perform "Create Derive" to create the derived component
3. In the derived component, create a user param called "scale_factor" and give it a unitless value of "1" as described above
4. Apply a non-uniform scale to the component, and for the direction you want to mirror, enter the "scale_factor" param
5. Go into the user parameters again, and change the value to -1
It will now be mirrored, the link to the original component is preserved, and any feature changes you make to the original component will apply to the derived component.
I hope Autodesk never classifies this as a bug. The user param workaround shouldn't be necessary because the scale factor input box seems to validate negative inputs, but it will clearly compute the geometry with negative inputs just fine as long as you "backdoor" them with a parameter change. It should really just allow negative inputs so the param backdoor isn't required.
Message 15 of 20
mikahb
Man, just had to do this again.  Kind of sad that 5 years later there's still no good way to create a related, mirrored part without this "one weird trick."
Message 16 of 20
ohboyd
Community Visitor
Community Visitor
I know this is an old topic, but I also have a desire to create a mirror component. I spent my career with PTC Creo, and with that program to do this you save a copy, select mirror part, and chose options to either make it a dependent or independent copy, and there you go. I am mystified that this is so difficult in Fusion.
Message 17 of 20
MichaelT_123
Hi Mr. Kristof Pucejdl,
As I telepathically understand the "programmatic process" of mirroring components in Fusion...
no body or component is touched directly. Instead, their reference coordinate systems are intelligently transformed (as delicately as by changing the signs of the coordinate matrix array). So, it is natural that the original component can not be removed.
There may be a trick to address your (and others') dilemmas, e.g., weights and moments of inertia.
Such meta processes could be enhanced with additional logic that recognizes the mirrored status of a component/body and acts accordingly, even in a simple way, such as ignoring it in calculations for entities invisible in the design space.
Regards
MichaelT
MichaelT
Message 18 of 20
lauri_barnhart
Welcome to the community, @ohboyd.
Hope you are well. Checking in to see if the information provided by MichaelT_123 clarified your question. Any update you can give would be greatly appreciated.
Let us know how we did on Trustpilot.
Lauri | Community Manager
Message 19 of 20
ohboyd
Community Visitor
Community Visitor
Hi Lauri, I don't think MichaelT_123 was addressing anything about my comment/question.
Message 20 of 20
MichaelT_123
Hi FusionFellows,
I have decided to add more narration to "Mirroring in Fusion."
It will not solve the problem, but...
I hope it will give you some Hope!
I'll present the story digest in a separate post.
Ref: https://forums.autodesk.com/t5/fusion-design-validate-document/mirror-assembly-component/td-p/142851...
Regards
MichaelT
MichaelT
