Mirror Assembly/Component
MichaelT_123
Advisor Advisor
MichaelT_123
Hi Fellows,
The method I sketched in my previous post obviously has some benefits (quoted below).
One was the ease of implementation on the F360 side; it also didn't risk breaking things along the way. Some should have a little bit of compassion here!... and particularly those who "ride" free Fusion instead of, e.g., Creo,…
Please find below the mirroring process described only verbally, as I believe that after so many years of experience in CAD systems, most Experts will be able to recreate it without a hitch.
So here we go:
  1. Take your assembly part; it can have joints and be parametric
  2. Call the Mirror feature
  3. For what to mirror, select Features
  4. Unfortunately, features of the assembly cannot be selected wholesale
  5. Go to the timeline and select them one by one
  6. I haven't scratched my head hard enough to figure out what to do in a multilevel assembly!
  7. Click OK
  8. You will discover mirrored bodies in the assembly's components
  9. One by one, remove the original, non-mirrored bodies
  10. Hopefully, you will end up with the new mirrored assembly, parametric, with joints intact, and with the matching timeline.
  11. Check the physical parameters of the original and mirrored assembly (e.g., mass, volume,...).
  12. They should be almost identical
  13. Open a new design and import your "left" and "right" subassemblies
  14. Deal with joints and motion links between those two as required
  15. Mind you, "left" and "right" are fully independent and, as such, can be modified/customized as required
  16. If you have embossed text features, try not to select them as in point 5; preferably, add such details closer to the final design's finish line.
  17. Yes, it might be a lot of macka gee-gee for the Creo Devotee, but fans of classical music also switched to rock and roll… and, as we know, quite easily (even a broomstick like can dance the latter).
  18. And, hey, what fun they have …
  19. In the grand scheme, it would be beneficial for dopamine levels, remembering that some CAD licenses cost tens of times more than Fusion. I am fairly sure that many of you would pinch some funds, would you not? TF360 will work after hours, then, to deliver mirrors… Be generous! Are you still there, Mr. Ohboyd?
I implemented the above points (without dancing and such) on a simplistic test assembly.
Perhaps there are also some other methods…but…
Below are visuals from the test. I didn't include the F3Z file; you can recreate it for your specific scenario.
On the final Personal note,
… any additional problems… knock on Fusion's doors!
On the final TF360 note,
… a simple geometrical process "injection" could make mirroring as easy as for Alice stepping right into Wonderland. Although simple, it would require changing the base of the geometrical calculation path.
For convenience, I insert some of my input from
Ref: https://forums.autodesk.com/t5/fusion-design-validate-document/how-to-properly-create-a-mirrored-com...
As I telepathically understand the "programmatic process" of mirroring components in Fusion...
no body or component is touched directly. Instead, their reference coordinate systems are intelligently transformed (as delicately as by changing the signs of the coordinate matrix array). So, it is natural that the original component can not be removed.
There may be a trick to address your (and others') dilemmas, e.g., weights and moments of inertia.
Such meta processes could be enhanced with additional logic that recognizes "the mirrored status" of a component/body and acts accordingly, even in a simple way, such as ignoring it in calculations for entities invisible in the design space.
MirrorAssembly_mono.mp4               5K_mono  (6.8MB)   https://a360.co/4AEHcfn
MirrorAssembly_arcd.mp4                 5K_stereo (9.9MB)   https://a360.co/4xT267S
MirrorAssembly_arcd_render.mp4   4K_stereo (1.6MB)   https://a360.co/3WSNpES
MirrorAssembly_mono.png               5K_mono   (3.4KB)    https://a360.co/4xR1W0D
MirrorAssembly_mono_render.png 4K_mono   (2.2KB)     https://a360.co/3WuX6JB
MirrorAssembly_arcd.png                 5K_stereo  (3.1KB)     https://a360.co/3TyobKE
View on 4K, 5K, and 6K media devices (monitors, UHD TVs, projectors...) with reasonable performance. For the best experience, use stand-alone media applications (WMP, VLC) and set the native resolution to 5120x2880 in full-screen mode. The '_arcd' files require anaglyph red/cyan glasses, while '_al' is for active shutter glasses 3D hardware (~30 deg viewing angle is recommended). Download the files over a network, where cost isn't a concern. The files are intended for private, non-commercial use only.
Regards
MichaelT
P.S.
And, oh, oh, oh…
Please don't hurt my feelings by saying you haven't benefited from the above post!
MichaelT
dominik_zarczynski
Hi Michael, if I understand correctly, you'd like Fusion to natively create a fully independent, parametric mirrored copy of an assembly while keeping its structure and joints intact. Is that correct?
If my answer helped you, please click Accept Solution. Thanks!
Dominik Żarczyński
Customer Technical Success
My Screencasts | Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
MichaelT_123
Sz.P. Dominik Żarczyński,
The short answer is: YES.
You understood the "Alicja w Krainie Czarów" metaphor correctly.
On the slightly longer digression...
Given the robustly constructed geometric paths inside a component object (child components, bodies, planes, joints, etc.), implementing the mirroring feature at the assembly level shouldn't be that difficult.
At the onset of a component creation, its transformation matrix is just the identity matrix ( I: all 3x3 diagonals equal +1)
Once again, given the robustness… a sign change in any diagonal element will mirror an assembly across the complementary plane (x@(0,0) = -1 will mirror across the YZ plane at (0,0,0)).
Perhaps I don't need to add that if I set x@(0,0) = -2, the component and its constituency should be not only mirrored but also scaled by a factor of 2.
So, adding a simple sign switch to the component's intrinsic coordinate-system metrix would upgrade Fusion Ultimate to Fusion Ultimate&Beyond.
But for the curious, there is also "beyond" beyond Fusion Ultimate&Beyond!
How to go there?
Create a Separate Matrix Object (SMO) that can modify (by simple multiplication) the component intrinsic coordinate system matrix. In that case, mirroring, scaling, and selecting the scaling/mirroring origin point … would offer unprecedented enrichment in what one could do at the component level and at the assembly level. So, we would have Fusion Ultimate&Beyond&Beyond!
Would there be some "beyond" beyond Fusion Ultimate&Beyond&Beyond,
Shure, not only "would", but it is!... and it is as simple as breaking a mirror.
Instead of creating SMO in real number space, represent its elements as a functional field.
For example, One, could define x@(0,0) = log(x), changing the scale along the x-axis from linear to logarithmic. The final result will still be presented/translated by the geometric path into familiar linear coordinate space … but what you see on the screen would be distorted … logarithmically.   I anticipate that Fusion Ultimate&Beyond&Beyond would be a very popular CAD tool for those willing to space-travel in the vicinity of black holes.
Now, the serious question!
Is there something beyond Fusion Ultimate&Beyond&Beyond…?
I am pretty sure that you know the answer by now.
Of course, IT IS!
Post-addendum.
I forgot to add...
The SMO should become the intrinsic element of the Component (top assembly) Object.
That would make dealing with the latter (inserting, exporting, pasting...) non-problematic.
Pozdrowienia
MichaelT
MichaelT
dominik_zarczynski
An improvement request has already been submitted regarding this.
Dominik Żarczyński
MichaelT_123
Hi FusionFellows,
 As I have been drawn to the assembly subject, I found some additional related (although loosely) resources.
They are rendered versions of already posted visuals. The foundation post MP4 & PNG file list has been updated with two additional files (MP4 & PNG), each with the suffix "_render" in its name.
Rendering is a touchy subject, particularly when presenting the final fruit of fruitration, dealing with quirks in Fusion, and, for that matter, in any other CAD software of your choice. Don't you agree, Mr TrippyLighting! 🙂
Regards
MichaelT
MichaelT
