How to print a 1:1 scale sketch from Fusion 360 to paper?
moller.g.peter
Message 1 of 14
moller.g.peter
Not sure this is a F360 issue and I'm not even sure this is possible but I'm trying to take a 2d sketch of a floor plan I've made in F360 where e.g. one side (A) is 495mm and when I print it out on A4, A3 etc. I want to be able to measure 495mm on the paper but so far nothing works for me. I've tried Autodesk viewer, F360 .dxf->Incskape .pdf->foxit viewer->print but no luck.
Any clue to how I can achieve this?
Replies (13)
Message 2 of 14
wersy
Make sure that you set your printer to print 1:1.
Not aligned to paper size!
Message 3 of 14
jhackney1972
The process is outlined in the video.  A sketch comes in to a 2D drawing as phantom lines, the video will show how to change the linetype.
John Hackney, Retired
Message 4 of 14
Warmingup1953
You say 495mm....Can we start with say a 200X200 Square...Can you get that printing OK?
Message 5 of 14
moller.g.peter
Thank you! It's very close but I'm only allowed one sheet (one piece of the entire image).
I have selected printer, paper size A3, orientation, scale 1:1, no offset, "current sheet".
In the print preview window I can't click "next" or "previous" which indicate it will only view/print the current view that I can see in the preview window but the image is so much larger. I tested printing and it confirms my suspicions, I get a piece of the bottom left corner only of the entire image. I tried changing the "Print range" options from "current sheet" to "All sheets" and "sheets in range" but nothing changes. Other things I've missed perhaps?
Message 6 of 14
jhackney1972
Your sketch is too large to be printer 1:1 on the selected paper size.  You need to choose a different scale or paper size.
Message 7 of 14
moller.g.peter
I was hoping that I could have the 1:1 image printed on as many A3 as needed for a complete imageand later stitch all papers together like a puzzle since the printer can only take max size A3, not A2 or A1.
Message 8 of 14
moller.g.peter
Ok I got it. I'm sure there is a much more convenient way to solve this but since I've never done this before, this is my solution with free software.
I exported my 2D sketch from F360 as .dfx file, imported it into Inkscape and converted it into .pdf, imported that .pdf into Acrobat Reader where I opened the printer dialogue, there I chose "Poster" in the Page Sizing section, then did my printers settings and it came out exactly 1:1 size 🙂
Message 9 of 14
g-andresen
You can also do this from the drawing  in Fusion (custom size).
File > Print > print to PDF ...
günther
Message 10 of 14
moller.g.peter
Problem is that the available "Paper size" settings does not allow me to go larger than A3 (I guess this is because of the printers possible range) and my current floor plan has almost the size of an A1. So I end up with my previous issue, that I only see the bottom left corner of the entire floor plan. Had the option of larger paper sizes been available, then sure! But with this setting I'm dependent on the printer's physical paper-size limits, in my case A3 is the biggest I can print per sheet
Message 11 of 14
g-andresen
just have a look at my screencast in this thread #9
günther
Message 12 of 14
leon38LUM
I tried the recommended solution (Fusion Sketch -> DXF -> Inkscape -> PDF Poster) but when I import my large file into Inkscape it doesn't set the page size correctly so my sketch doesn't fit and the PDF only have a faction of the image on it.
What am I doing wrong?
Message 13 of 14
g-andresen
1.There is no reason to use Inkscape.
2. Fusion > print> select print to PDF > select size
günther
Message 14 of 14
leon38LUM
Thank you but my sketch is large (about 100cm x 40cm) when converting it to a diagram, because I use the free version of Fusion 360, I don't have access to custom sizes so I can not create a drawing large enough to fit. That's why I believe I need to go through Inkscape. Am I missing something?
