Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
How to perform a pattern on path of a swept profile
2 REPLIES 2
domokaidus
186 Views, 2 Replies
Hello everyone,
I'm currently trying to repeat a swept profile around a body using pattern on path function.
As you can see, my swept profile is repeated but I can't figure how to make the sweeping function to follow to blue guide line for iteration #1 to #5.
Maybe I'm not using the correct approach but I was having difficulty to repeat my sketch profile with a specified distance between each of them before "sweeping" them off.
Any help would be greatly appreciated!
Labels (1)
2 REPLIES 2
TrippyLighting
in reply to: domokaidus
That can not be done with the pattern along path feature. You'll have to sweep each section individually.
domokaidus
in reply to: TrippyLighting
Thanks for you help, much appreciated
Regards
Technology Administrators
