Hello everyone,
I'm currently trying to repeat a swept profile around a body using pattern on path function.
As you can see, my swept profile is repeated but I can't figure how to make the sweeping function to follow to blue guide line for iteration #1 to #5.
Maybe I'm not using the correct approach but I was having difficulty to repeat my sketch profile with a specified distance between each of them before "sweeping" them off.
Any help would be greatly appreciated!
Solved by TrippyLighting. Go to Solution.
That can not be done with the pattern along path feature. You'll have to sweep each section individually.
