Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
how to open corrupted recovey file
22 REPLIES 22
Message 1 of 23
gurinderjeetsingh7
1073 Views, 22 Replies
I was warking offline and on a model and it was untitled ant not saved yet. suddenly a window came that fusion 360 stops
i restart application/fusion and when i click on my recovery file there come failed to open.corrupted file.this is for second time so i want to know that is  there is any ay to open that recovery file . it is very important so please respond as fast as possible
otherwise i discountinue usiong fusion 360
22 REPLIES 22
Message 2 of 23
Hi @gurinderjeetsingh7,
Welcome to the Fusion 360 Community!
Can you please email your diagnostic log files (found in the help menu of Fusion 360) to james.youmatz@autodesk.com. This should give me an idea of what is happening as well as where the recovery file is stored on your computer. My thought is - we can pull the recovery file from your hard drive, and then I can try to open that file on my machine, debug if neccessary, and then forward the model back to you so you can upload the model. The logs might give us a better clue as to why this happened as well.
I apologize for the inconvenience and look forward to your response,
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
Message 3 of 23
Here is the diagnostic log
Sent from Yahoo Mail on Android
Message 4 of 23
I attached diagnostic log
Please help me
I have also emailed it to the email you given
Message 5 of 23
Thank you for sharing Smiley Happy
I've reported it and they need the corrupted file. could you provide us it? my email address is ahreum.ryu@autodesk.com
I look forward to your reply.
Many thanks,
Ahreum.
Message 6 of 23
But where I find the corrupted file
Message 7 of 23
Could you take a look at this?
C:\Users\USER NAME\AppData\Local\Autodesk\Autodesk Fusion 360\USER ID\W.login\F
Please let me know the corrupted name and error messages.
Thank you for your help!
Many thanks,
Message 8 of 23
sir there are seven untittled files so how can i find the corrupted file
Message 9 of 23
Oppps! I see I'm going to ask them, so May I know the error message when you open the file?
it will appreciate if you can capture it Smiley Happy
Many thanks,
Message 10 of 23
i also want to share that when i was looking in appdata----fusion 360then i didn"t find the user id folder so there was a folder named unknown user i opened that but in that folderwas empty
but when i started fusion360 and look for recovery document then the same problem apper again
Message 11 of 23
hum.... I need to check with Dev team I will be back as soon as possible. Smiley Sad
sorry about that!
Many thanks,
Ahreum
Message 12 of 23
Did you find any solution I am very upset because I worked very hard for that project .Please reply
Message 13 of 23
I'm sorry about that. They are investigating your log file
I'm asking it again. I will be back as soon as possible Smiley Wink
we truly appreciate your patience.
Many thanks,
Message 14 of 23
Thnx for your help .Please reply soon with a solution
Message 15 of 23
could you take a look at this folder??
C:\Users\USER NAME\AppData\Local\Autodesk\Autodesk Fusion 360\FZ3WRAAX6HZ4/CrashRecovery
Is there any other file there??
Many thanks,
Message 16 of 23
i didn't find the crash recovery folder in FZ£WRAAX^HZ$ that was in folder names local but i go back and open roming folder there i find that crash recovery folder and i found two files and when i try to attach that siles a error comes that ::'the file does not have a valid extention for an attachment and has been removed'' . so now what to do ?
Message 17 of 23
Hi I sent private messages, could you please reply me?
Message 18 of 23
please take a look on this video
Message 19 of 23
i sent a private message so plese take a look on it
Message 20 of 23
here is all the three files
I was thinking that '0a85019c97f94444bad14e1473f093.zip' is my full project
actually my project is a suv car so hope you can find it
ones again thanx
and sorry! i didn't email it
