@prscustom - the problem (it may be obvious, but IMO worth pointing out), is this point in the upper spline:
It seems to be "locked" for movement, no matter what I do. Even if I delete the coincident constraint, and move the circle away from it:
I cannot move this point - either by dragging or with Move. It is not locked, and appears to have no constraints on it. So, that is the root cause of the problem here. If I delete that spline and re-create it, everything moves just fine.
So, the question to you is: Do you have any recollection of how that spline, and particularly that point was created that might have caused this? Any constraints that existed in the past?
I'll continue to look into this as I have time. Something weird is going on, definitely
Jeff Strater
Engineering Director
