How to modify a body in the sculpt workspace so that it can covert to a complete body?
360taiphi
Message 1 of 10
360taiphi
I am having some trouble completing this model after exiting the sculpt workspace. I need advice on how to model it so that it I can work on it in the patch workspace.
I am having trouble uploading a screencast and I don't know how to delete this message. I will try again.
Replies (9)
Message 2 of 10
jeff_strater
we'd need some more information to help you.  Preferably, the design itself.  Can you Export the design as a Fusion Archive (F3D), and attach it here?
Jeff Strater
Engineering Director
Message 3 of 10
laughingcreek
the dialog for attaching screen casts at the bottom of posts has been broken for some time.  just put a link to it in the body of your post, or embed the HTML.
Message 4 of 10
360taiphi
Ok, I attached the file. Let me know if you got it.
If you go into the folder Front Bumper you will see Front Flare. I want to use it to split the Shell, then delete the resulting inner face of the Shell so that you could see the Flare design. Also, I was having trouble creating a patch for the back of it so that you wouldn't see right through it into the car. I created Bodies 55, 56, and 57 by seperating the body into three parts and using it as such. It worked but I prefer to have it as one whole Body. If you have any better ideas I would appreciate it.
Let me know what you think of the design overall and what else I can do to improve it.
Message 5 of 10
360taiphi
Thanks. How do I attach it to the body of the post? I can't seem to find my way back to it.
Message 6 of 10
laughingcreek
one way to get to your uploaded screen casts-
Message 7 of 10
laughingcreek
I would suggest over building all your surfaces.  the front flare doesn't fully intersect the shell.  you will need to pull the edges out so it comes complete through the shell if you want to use it as a trimming tool.
transitioning from a t-spline to the nurbs space, and doing further nurbs surfacing tasks is tricky, and there are a number of pitfalls to look out for.
-surface geometry around star points will always be a bit wonky.  so you want to place them in areas of low curvature, instead of areas of high curvature like you have here-
creases should be minimized (or eliminated completely) in t-splines, but if your going to use them, never run them through or into a star point-
-avoid anything but 4 sided faces, especially around geometry like wheel wells-
avoid all of the above with better topology.  for instance, use edge loops around the wheel wells-
Message 8 of 10
TrippyLighting
When it comes to modeling vehicles with T-Splines I can recommend Gichi Endo's YouTube channel.
He stands out amongst the many YouTubers who create Fusion 360 tutorials, because he's actually an accomplished pro with real-world experience.
Another channel I can hotly recommend for Sub-D and T-Spline modeling is Arrimus 3D !
Message 9 of 10
360taiphi
Awesome, thanks man
Message 10 of 10
360taiphi
I will check them out, thanks
