How to model a GT2 pulley profile, please?
i-make-robots
Message 1 of 12
i-make-robots
I don't have engineering textbooks, youtube doesn't appear to have a useful example, and my most clever googling hasn't born fruit.  Please!  Show me the magic.  I have the straight belt profile:
and I don't know how to convert that to work around a circle.  If you would be so kind, I would really love to know the secret.  Ideally in a way that I can generate other round-tooth profiles for other metric belts, too!
Thank you,
Replies (11)
Message 2 of 12
mavigogun
The actual shape of the sprocket teeth is an engineering question.   Sketching those teeth I might  start with Circles at the bottom and top of the tooth extents, then Lines radiating out form the center point defining the degree arc of half a tooth profile; Mirror that profile, then Circle Pattern the combined product.
Message 3 of 12
etfrench
In this thread @davebYYPCU shows how to draw a GT2 pulley.  I still use Gearotic to generate the pulleys.
ETFrench
Message 4 of 12
webweave
Here's the best one I could find.
https://youtu.be/qV_C6Xu-WKY
Message 5 of 12
MichaelT_123
Hi Mr. I-Make-Robots,
There are a few solutions which come to mind:
  1. An experimental one – real pulley imprint in a thermally settable patty.
  2. Numerical approach. Perhaps if you are reasonably math/programming skilful the modification of Mr. Ekins script as proposed in (https://forums.autodesk.com/t5/fusion-360-design-validate/spur-gear-design-script-problem/m-p/880924... could arrive in a long-lasting more or less sophisticated solution.
  3. The semi-empirical solution (which can be done entirely in F360) can be devised by modification of the example given in https://forums.autodesk.com/t5/fusion-360-design-validate/need-rollers-that-conform-to-cable/m-p/871...
 Regards
MichaelT
MichaelT
Message 6 of 12
b.sattmann
Community Visitor
Community Visitor
I know this thread is old, but I gave it a try and I think i managed to recreate a sketch from your textbook.
I used 3 circles and connected them via bent lines (drag with the line tool; L key). I cheated a bit using dummy lines for the bent lines to hold onto. Then I gave everything the right dimensions using the D key and connected everything using the "Tangent-Constraint". Finally i trimmed the unnecessary lines using the T key for less clutter.
Maybe that helps a few people that find this thread somehow.
Message 7 of 12
Take the SCAD file from this thik in thigiverse
https://www.thingiverse.com/thing:16627/files
edit the file to get the pulley you want (beter with OpenScad)
open the SCAD file with Freecad
export to STEP file
now open With Fussion
Message 8 of 12
etfrench
I would not rely on a Thingiverse model to be accurate 😀  In this screenshot, orange is the Thingiverse model for GT2-3mm-13 tooth pulley, while the blue is from Gearotic.
Which would you rather use?
ETFrench
Message 9 of 12
vewoci6695
Observer
Observer
Not spending $120 sounds wonderful. 😀
Found this thread while asking the same question. Given that I'm going to be using a (cheaper) 3D printer and it will not be hugely critical the part is 100% accurate I don't think a little error is going to matter. I'll take the free version over spending quite a bit of money.
Message 10 of 12
etfrench
3d printed timing pulleys work really well. I've been using them on my rose engine for several years now.  I just added linear glass scales and found the error over 10" was less than 0.0005".  The timing pulleys are GT2-3mm with a 5:1 reduction.  Leadscrew is TR8-2mm.
Follow @davebYYPCU 's instructions and you shouldn't have any problems.
This image was taken before adding the glass scales:
ETFrench
Message 11 of 12
vewoci6695
Observer
Observer
Cool!
I'm going to be using GT2 3mm pitch as well. My printer is on the cheap side so I doubt I can get them too terribly accurate. I'm more worried about the 6mm wide belt handling the load. It may be fine but we'll see. I seem to be having issues finding good availability for belts (and pulleys) with all the supply issues people are having.
Message 12 of 12
etfrench
What size pulleys do you need?
I've had good luck with Royal Supply for belts.  They do have a minimum order amount.
ETFrench
