How to merge lines?
How to merge lines?
jmceara
How to merge lines?
jmceara
Community Visitor
Community Visitor
Hi!
I think it's a basic question, but how can I merge lines from the same sketch?
Let me explain: I have draw a rectangle and a circle, in the same sketch. What I want is to delete some lines (see picture) to 'merge' and create only one thing......but I can't select circle-parts, only full circle. When I try to select only one small part of circle (that overlaps rectangle, for example), full circle are selected, then I can't delete only that piece.
What am I doing wrong? How can I select one the part of circle that overlap rectangle?
MRWakefield
Trim, although it's often better not to, but that's up to you to decide 😉
If this answers your question please mark the thread as solved as it can help others find solutions in the future.
Marcus Wakefield
____________________________________________________________________________________
I've created a Windows application (and now Mac as well) for creating custom thread files for Fusion. You can find out about it here. Hope you find it useful.
If you need to know how to offset threads for 3D printing then I've created a guide here which you might find useful.
If you would like to send me a tip for any help I've provided or for any of my software applications you've found useful, you can do this via my Ko-Fi page here.
TheCADWhisperer
Your sketch isn’t fully defined.
You don’t really need to merge anything.
