how to measure perimeter of a circle?
I am using Fusion360.
can someone explain me how to measure a part of a circle?
ex: draw a circle
      draw a line through the circle
      how to measure the part of the circle between the points that cut the circle?
so I would like to know how to measure the length of the part of the circle. not the distance between two points of a circle, neither the diameter.
Thanx!
HughesTooling
Either trim the circle and measure or extrude then measure the edge of the solid.
Mark
Mark Hughes
Owner, Hughes Tooling
Cool!
Thanks a lot!
etfrench
The Break command can also be used.
ETFrench
