editing exported dwg
Is it possible to edit fusion 360 exported dwg files in acad or acad LT?  When I export as dwg it generates the drawing as a block that cannot be edited or modified in cad.  Is there a setting that controls this?
DDMFGCOINC
@Anonymous
The only way to edit the exported .dwg that I know of is to use the exportlayout command, in AutoCAD, which will open the layout in a new window.
