How to make the sides of a cube concave?
karl
karl
Id like to design a cube where the four vertical sides are slightly concave.  Is a revolve (using the concave profile) the "best" way to do that?
davebYYPCU
Not if the corner edges have to be straight.
Use Loft to an indented centre point with Tangent option, or you get a four sided pyramid.
Might help….
karl
Thanks, but I want the four corner edges to curve in, too.
laughingcreek
I think you might want to better define the problem with a hand sketch or the like.  there are lots of interpretations for "a concave surface".
here's mine based on the current verbal description-
karl
Sorry for the ambiguity.  Here's what I'm going for (rectangular solid in example, not a cube):
laughingcreek
sweep.
karl
Thanks!
