How to make slope edges
piotrszpruta
Message 1 of 8
piotrszpruta
Hello, I have my 3D model and I made drawing with fillet on the corners. After that I've extruded it with taper angle -4.0 deg to have small slopes. But my fillet is collapsing. Do you have any idea how I can make slope walls without breaking fillet extrude?
Sorry if I'm not being clear what I need.
Replies (7)
Message 2 of 8
wersy
To solve a problem, it is almost always necessary to examine the file.
It is best to always upload the file as well.
Message 3 of 8
piotrszpruta
How I can share file? Is it okay to upload F3D?
Message 4 of 8
piotrszpruta
Message 5 of 8
davebYYPCU
Extrude the square corner rectangle, add fillets in modelling window.
Might help…
Message 6 of 8
piotrszpruta
So I should extrude square without fillet corners and then make them rounded?
Message 7 of 8
davebYYPCU
Yes, that’s what looks like you wanted.
Might help…..
Message 8 of 8
TrippyLighting
Yep. Fillets should be added as solid, or surface fillets whenever possible.
It's not always possible, but generally avoid fillets in sketches!
