How to make round corners?
CreekWalker
CreekWalker
I want to fill out this black with material, so the corner are more soft.
But how can i do that?
step by step, 1,2,3...
Uber beginner
jeff_strater
Hi @CreekWalker,
It somewhat depends on how this model was created.
If it was created in Fusion using the Fillet modeling feature, the simplest is to just edit the fillet feature that created the small corner, and type in a new radius:
If the model was created in Fusion using sketch fillet, then edit the sketch, and edit the fillet radius there:
If the model is imported from somewhere else, then you'll have to delete the small round face and add a new fillet:
Hope one of these works for you.
Jeff
Jeff Strater
Engineering Director
kb9ydn
Is Fusion eventually going to have a face fillet option, where you can select faces to blend instead of edges?
C|
jeff_strater
Yes, definitely, face/face fillet is high on the list.
Jeff Strater
TheCADWhisperer
From your image it appears that you might be interested in a Variable Radius Fillet.
