How to make a straight object flush with a curved object
miaoke6P3L2
Message 1 of 9
miaoke6P3L2
Hi
Can anyone please show me how to make pictureA looks like pictureB please. I wanted to make the grey object flush with the yellow object.
Thank you
Sabrina
Replies (8)
Message 2 of 9
davebYYPCU
Early in the timeline, the yellow dome has no hole in it.
Make the tube you want to change, as an Extrude to Object, before you combine > cut the grey body out of the yellow body.
With such a colourful timeline, I have my doubts, it will work.
Might help.....
Message 3 of 9
jhackney1972
You do have a lot of issues in your timeline!  Basically what I did was to add a Surface Offset of the area around the hole BEFORE the hole was created in the timeline.  I then had to Offset Face of the threaded body to give enough length to be cut flush with the offset surface.  I then used the Split Body command to split the threaded body and then removed the excess material.  Your model is attached.
If this answers your question, please select the "Accept Solution" on my post. If you need further help, please ask.
John Hackney, Retired
Message 4 of 9
TheCADWhisperer
@miaoke6P3L2
Would you like to learn step-by-step how to do ALL of this correctly?
Message 5 of 9
miaoke6P3L2
Hi, thank you for the file, that's what I want, but I still don't know how to do it.
I'm very new to fusion, so I don't understand your explanation, like how to offset face of the threaded body.
Thank you
Sabrina
Message 6 of 9
jhackney1972
I am traveling and my traveling computer does not have an internal microphone. I recorded a video of how I created your model but it has no sound.  I hope it is enough along with my previous description for you to understand the process.
Message 7 of 9
miaoke6P3L2
Thank you so much for this. I understand now.
Thank you again
Sabrina
Message 8 of 9
johnsonshiue
Hi! Another approach without fixing the timeline or moving the timeline is to create a zero-distance surface from the yellow body. Use Untrim command to restore the base surface. Lastly use Replace Face command to cut the bolt. Please take a look at the attached f3d file.
Many thanks!
Software Test Engineer
Message 9 of 9
miaoke6P3L2
Thank you, but I'm very new to Fusion, I have to go the easiest way.
Thank you for your help.
