Document/Configuration Info in Text Parameters
linrya26
linrya26
New parametric text feature has been great so far. I think adding a parameter/special token for the name of the current configuration so I can include it in text emboss operations would be very helpful. Also the Parametric Text Addon has these. Some other things could be the name of the document and component, current date/file export date, and the document version.
gautham_kattethota
Hi @linrya26
Thanks for posting about the usefulness of parametric text and how you are using it in configurations.  The workflow you are using is a pretty common use case for this feature.  Let us know if you encounter any problems with it.
Regards
Gautham
Gautham Kattethota
Software Development
