Can you offset an edge?
tookemtoni
tookemtoni
With a solid body, can you offset an edge like you can do with faces?  I just need to perform a simple operation on this geometry. see demo video and file link. https://a360.co/47C5zxA
(view in My Videos)
davebYYPCU
Using the Modify > Draft Tool, you need to know the required Angle, from the vertical face at the pivot position.
For a 4 mm adjustment, you would normally draw the line and dimension the lift (4mm), Measure the Angle.  But now that you have drawn the sketch, extrude the profile, set to Join.
Move (rotate) Face, will not make it the correct length.
Depends on how the current body was made, maybe edit the original sketch, but I see the sketch has no dimensions.
Might help….
tookemtoni
Of course you can do it this way but it's so tedious. Make a sketch and extrude join....see video demo
(view in My Videos)
tookemtoni
thanks @davebYYPCU, works but I dont know the angle.  I wish for a easier way.
davebYYPCU
Drawing a 4mm line, and join the top of it to the corner of the rectangle, not easy enough - you are in the wrong game.
Add the new profile section to the original Extrude.
g-andresen
use a calculated angle
(view in My Videos)
günther
