how to make a item in a pin slot turn from a point in the middle of a slot
2 REPLIES 2
19stewag
182 Views, 2 Replies
i am trying to make a mechanism so when one joint is turned it causes other panels to turn and slide down. the only problem is that when i try to move where the origin of the slider is it is fine but it where it rotates from is the point where I had to select a joint because the point I want it at is undefined.
here is a pdf of a drawing of the model. cant get screenshots to paste
2 REPLIES 2
TheCADWhisperer
in reply to: 19stewag
19stewag
in reply to: TheCADWhisperer
i figured it out. what i needed to do was drive the joint to the desired place form a defined point.
