How to join two objects that are not connected with a diagonal extrude?
SimonPlatten
SimonPlatten
I have two objects, the top object is 250mm in diameter, 2mm thick and 2mm in height.  Another object under it is 230mm in diameter, 2mm thick and 10mm in height:Screenshot 2024-12-29 at 13.36.31.png
I would like to join the top of the bottom object to the bottom of the top object with a diagonal section that is also 2mm thick, can I do this with some feature in Fusion 360?
jhackney1972
Please attach your model.
John Hackney, Retired
SimonPlatten
Thank you, attached is the file so far.
SimonPlatten
Done it, added a new sketch with the profile of the join and used sweep.Screenshot 2024-12-29 at 13.57.17.png
jhackney1972
Your model does not match your original description.  You stated the two rings were 2mm thick, they are 1mm thick.
SimonPlatten
Ok sorry, my error, but the thickness doesn’t matter.
g-andresen
A tip for next time.
günther
